Motor PRofiler gives "Firmware Error 0.2", Flashes boards and stops working
shorai
When I try to connect with pollling on, the Control and power board flash briefly before going white
   The error displays for a time
The application is unusable.
If I switch polling off, I can connect to the board but the application still does not work
    I also get a confusing "Port Open and try to configure the board" in the connection dialog and  simultaneous "Baord Discconnected" in the application panel
WHat does the error mean?
Can we not get a decent error message displayed?
Works with bull running motor, but not with others
If polling is switched off, the board connects and sometimes lets me start a profile, but does not get any results.
Most often the buttons are all greyed out and the input fields are inaccessible
Terminal has the following line which may be of use
ASPEP_BEACON Mismatch on crc_cpacility RXS_Max TXS_Max TXA_Max
Unfortunately the  terminal content is in a table and needs to be copied cell by cell
Here is the Log
[INFO] - : Application is starting : MotorPilot version:1.2.5
[INFO] - : ini file path=C:/Users/Crows/AppData/Roaming/ST Microelectronics/ST Motor Pilot.ini
[INFO] - : Polling time out is set to 200 ms
[INFO] - : set qml to : qrc:/GUI/profiler.qml
[INFO] - : sdkPath=C:/Program Files (x86)/STMicroelectronics/MC_SDK_6.2.1
[INFO] - : Loading registers bank desciption file C:/Program Files (x86)/STMicroelectronics/MC_SDK_6.2.1/Utilities/PC_Software/STMotorPilot/RegisterList/RegListProfiler_MCPV2.json
[INFO] - : Registers bank description loaded successfully
[INFO] - : Load Application qrc:/GUI/profiler.qml
[INFO] - : QML Application ready
[INFO] - : Connecting to Board
[INFO] - UART worker: Successfully open port COM6 @ 115200
[INFO] - : try to configure the board
[INFO] - : Connected to board
[ERROR] - MotorControlProtocol: ASPEP_RESP ERROR:CMD_UNKNOWN
[INFO] - : Disconnected from board
[INFO] - : disconnect UART START
[INFO] - : disconnect UART END
1 REPLY 1
GMA
Hello @shorai,
It is a known issue on Motor Control Pilot version:1.2.5.
Could you please try with our latest version available here.
If you agree with the answer, please accept it by clicking on 'Accept as solution'.
Best regards.
GMA
