Error with Motor control after generating .ioc from STCubeMX from example for B-g431b-ESC
Tejashree
I am trying to run the example from motor control work bench for B-G4314-esc1 Electronic speed control.I generated ElectronicSpeedControl.stmcx and generated code in cubeMx.Now when i try to load the configuration in CubeIDE it is showing me error in motor control in initial build.
1 REPLY 1
cedric H
Could you provide the various versions of the tools you use. MC-SDK, cubeMX, CubeIDE.
Cedric
