Hello!
May be it is wrong ethernet DMA tail calculation?
‎2019-11-20 5:26 AM
In ethernet HAL driver stm32h7xx_hal_eth.c function void ETH_DMARxDescListInit include row: " WRITE_REG(heth->Instance->DMACRDTPR, ((uint32_t)(heth->Init.RxDesc + (((uint32_t)(ETH_RX_DESC_CNT - 1))*sizeof(ETH_DMADescTypeDef)))));"
This code adding value to heth->Init.RxDesc. But, RxDesc is pointer to 32bit and added shift is multiplicated for 4.
Correct row must be:
" WRITE_REG(heth->Instance->DMACRDTPR, ((uint32_t)(heth->Init.RxDesc) + ((uint32_t)(ETH_RX_DESC_CNT - 1))*sizeof(ETH_DMADescTypeDef)));"
- Labels:
Bug-report
Ethernet
Github
STM32H7 Series
‎2019-11-20 10:08 AM
Created an issue on github:
https://github.com/STMicroelectronics/STM32CubeH7/issues/7
Yep, this is why "better" languages like Go don't have pointer arithmetic. Too confusing. Causes more trouble than utility.
-- pa
‎2019-11-20 7:59 AM
RxDesc is pointer to ETH_DMADescTypeDef. 6*4 bytes,
-- pa
‎2019-11-20 9:44 AM
Pavel is right - RxDesc is a pointer to a structure. Therefore neither ST's, nor your version is correct because of C pointer arithmetic, but the correct version is even simpler:
WRITE_REG(heth->Instance->DMACRDTPR, ((uint32_t)(heth->Init.RxDesc + (uint32_t)(ETH_RX_DESC_CNT - 1))));
ST, this is a bug report and we're talking about this line:
P.S. ST's driver developers, who don't know C pointer arithmetic? Fabulous! Do they know arithmetic at all?
‎2019-11-20 9:49 AM
@Piranha ,
@AAshc​ 's version is correct, too, as he casts the pointer to integer before applying the + operator, and then uses sizeof() of the target type.
I personally am not fan of pointer arithmetics, as it's bit easily perceivable when fast reading code; and I recommend to explicitly comment all instances where it's used, or, maybe better, use it in the &a[b] form, which is more easily recognizable when reading the code.
(Strictly speaking, pointer cast to integer is not entirely correct, but then all three versions do some form of that).
‎2019-11-20 10:03 AM
Indeed, I stand corrected! I overlooked the braces in OP's version. Therefore only ST's version is flawed.
-- pa
‎2019-11-20 3:53 PM
I don't really care as I don't Cube, but is this limited to H7?
‎2019-11-21 10:44 AM
Yes, H7 only. Other STM32 series doesn't even have that or similar register. H7 has a different ETH peripheral than all other STM32 MCUs.
‎2019-11-21 1:03 PM
Oh, I see. Thanks for the explanation.
‎2019-11-28 2:54 AM
A good practice @Pavel A.​ ! Thanks for taking the initiative to report the issue there.
So the status of the progress can be followed on Github now.
