Nucleo User Manuals don't show the VCP UART connection
10 REPLIES 10
Also UM1724 for the Nucleo-64s:
UM1956 (Nucleo-32) just doesn't label the connection at all:
But UM1974 for Nucleo-144 boards (MB1137) does show it!
SofLit
An internal Ticket 174798 has been raised to fix the issue.
Thank you @Andrew Neil  for raising this.
PS:
1 - This is NOT an online support (https://ols.st.com) but a collaborative space.
2 - Please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help.
Reported also for UM1956 and UM1724
PS:
Probably also worth a general check on Discovery and other boards ...
@SofLit Any update on this?
The manuals have not been corrected yet, and this continues to cause confusion:
https://community.st.com/t5/stm32-mcus-products/communication-between-nucleo-f411re-and-raspberry-pi-using-st/m-p/721545/highlight/true#M261177
@Andrew Neil
Unfortunately not yet and I don't have a visibility on this fix.
The only info is just this will be applied to the new Boards' UMs. For the old ones I cannot confirm.
PS:
