Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
Finding a part from a Marking Code
Posted on May 11, 2018 at 18:17Hello,I am trying to find a part but all I have is the marking code because the part number got scratched off. This marking code might not be completely correct because part of it also got scratched but I am hoping som...
Timers
Posted on May 11, 2018 at 12:59Hi sir,I am working on the stm8s family micro controller. In that i am using TIM1 and TIM4 for timing delay. I configured PWM channels for timer 1. Before timers configuration program is running when ever entering in t...
Simple C Question
Posted on May 10, 2018 at 14:43Hi.I was trying to write a code to use my keypad, but I face a problem. Because I'm new in using standard libraries I didn't face a similar problem when I was using registers(in LPC series).#define COLUMN_PIN_1    GPIO...
STM8L151Gx ADC1 Conversion Value Retrieval Time
Posted on May 10, 2018 at 05:50I have a question rooted in pure curiosity as I am still learning my around the STM8 MCU structure. In the general setup of the ADC, single mode conversion and software triggered,  we have to call ADC_GetConversionValu...
The clocks each command takes
Posted on April 27, 2018 at 19:51 Hi. I wanted to know that for example how many clocks a while loop takes. Do you have any ideas or any articles on this matter? Note: this post was migrated and contained many threaded conversations, some ...
Low Side switch app note error
Posted on May 01, 2018 at 18:57Hi ST TEAM!I was reading through the low side switch app note http://www.st.com/content/ccc/resource/technical/document/application_note/group0/12/27/2b/c6/ba/ca/4c/16/DM00255001/files/DM00255001.pdf/jcr:content/transl...
Resolved! Cannot enter low power mode STM8L052C6
Posted on April 18, 2018 at 06:00Hi,I feel like I've been through the reference manual a million times, but I cant figure out how to get my project into low power mode.I'm driving a LCD screen with a counter on it. I have two external switches to wa...
Billy Bob by Associate II
  • 4384 Views
  • 4 replies
External interrupt flags latching behaviour?
Posted on May 10, 2017 at 10:46I am working on a code which utilizes External interrupts on the PORT B.STM8AF5286 is used with the Cosmic compiler.I have not found any information about how the interrupt flags are handled internally and knowing thei...
