Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
Jump to code in RAM
In the documentation for switching to low power run mode it mentions that you need to jump to code in RAM before shutting down the FLASH.How do you specify that code should be placed in RAM?OK Update:This is for the STM8L151F3.I found link to a sugge...
TVan.11 by Associate
  • 714 Views
  • 0 replies
I2C setting is not working for FP-ATR-LORA1 package (GNSS + LoRa asset tracker)
To reproduceEnable I2C in gnss_app_cfg.h#define configUSE_I2C 1When moved, the UART log said(11:58:08.056) -->�?�Going�?�to�?�run...(11:58:12.943) Can�?�not�?�read�?�axes(11:58:12.963) >>�?�sensor_event(11:58:15.875) Accelerometer�?�NOT�?�initialized...
SVora.4 by Associate
  • 1095 Views
  • 1 replies
VN380SP
I can't find any information about VN380SP at the st.com siteIs VN380SP discontinued? Deprecated product?
AShab.10 by Associate
  • 673 Views
  • 0 replies
STM8: mistake in datasheet?
Good morning.STM8S003: https://www.st.com/resource/en/datasheet/DM00024550.pdfOn a page 45 under table 15 (quote):"2. Do not use more than one remapping option in the same port. It is forbidden to enable both AFR1 and AFR0."Here first part of the sen...
Arlleex1 by Associate III
  • 754 Views
  • 1 replies
