Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
Please help me reverse engineer these buttons...
Hi,I am trying to figure out how a set of buttons interfaces with the microprocessor - an STM8S 003K3T6C ([url=https://www.st.com/resource/en/datasheet/stm8s003f3.pdf]datasheet[/url])I am familiar with simple button config - you pull GPIOs high or lo...
Rjohn.1 by Associate II
  • 2906 Views
  • 5 replies
STUSB4500_GUI cannot detect NUCLEO board
I am using a NUCLEO-F072RB with a STEVAL-ISC005V1 dev board. The STUSB4500_GUI is v1.11. The Nucleo firmware is V2J37M26. Windows 10. The NUCLEO board shows up as a COM port and as ST-LINK in the device manager.Running HwCheckUtility sees the COM...
WFord.1 by Associate
  • 1188 Views
  • 1 replies
Hi, My Onkyo receiver got frozen and behaving stubborn. Can I program M95640WP using CH341A Programmer any help in this matter shall be highly appreciated. datasheet included here https://ibb.co/1JTWkLs thanks in advance Modify message
Hi,My Onkyo receiver got frozen and behaving stubborn.Can I program M95640WP using CH341A Programmerany help in this matter shall be highly appreciated.datasheet included herethanks in advance
Pbhat.1 by Associate
  • 1481 Views
  • 4 replies
STM32F4xx and ESP8266 with SPI
Hello everyone i'm new here,My problem is i want to work with ESP8266 wifi module (mine is Adafruit HUZZAH ESP8266 i will share a link aswell...) via SPI protocol. I did some research and i couldn't fine any library/drivers or example about this. Th...
Can assembly code running on stm8s-dicovery board?
I have tested my stm8s-discovery board for 2 days. The MCU is stm8s105c6t6, the Hex format file produced in c language on the IAR EW platform, could run as expected when uploaded into the board, but the final file from assembly language, both in Hex ...
MQi.1 by Senior II
  • 1758 Views
  • 4 replies
using swim pin as INPUT foating pin.
as per datasheet of stm8s001j3 it has been mentioned that impact of pin mode while using other pins, ex. PD1 impacts PD6,PD5... so to disable the swim pin using Out Mode Low Level, would also impact in case want to set late for PD5 as IN Mode FL NO I...
SSing.61 by Associate
  • 741 Views
  • 0 replies
