Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
Resolved! Is the stm8s_conf.h exists ?
Dear experts,I have a problem with stm8s_conf.h file. I download the Standard Peripheral Libraries officially from ST web page. After I put them all into STVD, I mean the .c and .h files, then I compile. The compiler detects that stm8s_conf.h does no...
Mahendra by Associate II
  • 4244 Views
  • 4 replies
Resolved! Questions about MLPF-WB55-02E3 PCB assembly
Hello. I going to use MLPF-WB55-02E3 with STM32WB55V WLCSP_100.1 On the datasheet MLPF-WB55-02E3 there are recommendation for PCB assembly this chip. The document prescribes to use ground CPW line (on antenna side) with sizes as in the pictures Figu...
select Rbus versus Cbus Value (M24M01)
Hi,I'm trying to develop using the M24M01 product. There is a part in DATASHEET that I don't understand, so I leave a question.In the item 'Maximum Rbus value versus bus parasitic capacitance Cbus', it is stated that the Rbus X Cbus value should come...
yjin.1 by Associate II
  • 2860 Views
  • 3 replies
SPEAr(1340) USB Flashing utility
I need the most recent version of the SPEAr USB Flashing utility that works with SPEAr1340. Version 3.2.5 is listed on st.com but the download is decidedly not the USB flasher. The previous version download, v2.4, does download but doesn't work with ...
CBoyd.1 by Associate
  • 1035 Views
  • 0 replies
