Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
Resolved! L9735TR
Do you have a data sheet for this product? Has this product been discontinued? Is there a reference for alternative part numbers
xuzejian by Associate II
  • 1243 Views
  • 3 replies
  • 2 kudos
TL062 Pspice model
Hi everyone,I am working on a LTSPICE model for TL062 I think maybe you can help me :)This is the schematic diagram is the datasheet :and this is my spice model To test if my amplifier is working i am trying the basic utilisation for OpAmp : So I con...
fru999_0-1714486095109.png fru999_2-1714486206089.png fru999_3-1714486250161.png fru999_1-1714486147052.png
fru999 by Associate III
  • 1601 Views
Resolved! Create Time delay using 555 timer IC
Hi, I have create one adjustable multi vibrator circuit using 555 timer IC my aim is to achieve two things  1.Basically 555 timer IC output is Rectangular wave my aim is achieve ontime of one pulse 0-10us(Micro seconds) time delay  2.Another one is o...
Vignesh_V by Associate II
  • 1714 Views
  • 1 replies
Resolved! DRM is missing STM for DFU
Hi, When I connect a digital radio via the USB cable, Device Manager should show under USB: STM Device in DFU mode. However, it doesn't. Instead, I have an Other Devices: Digital Radio in USB mode, with a yellow triangle with black exclamation point....
Resolved! Help to identify the part
Hi all and good time :hand_with_fingers_splayed:can U help me please?i'm confused about this part with the (UM smd code),i searched a lot on google and but i found only 2 parts with this smd code... (zener diode and tvs diode) !!:thinking_face:my fir...
UM2.jpg IMG_20240427_091348.jpg bzx84j-c5v6.png Screenshot 2024-04-27 at 11-17-48 Bourns® Chip Diodes - Bourns-SMAJ15CA-datasheet.pdf.png
mazieis by Associate II
  • 1585 Views
  • 4 replies
  • 2 kudos
How to design universal analog input circuit
Hi,I'm designing a PCB that can get 8 digital inputs and 4 analog inputs. But these inputs can be range from 3.3v to 24v. For the digital inputs I have used universal logic shifter method using comparator where I can give any voltage range of digital...
jsw2000 by Associate II
  • 3212 Views
  • 4 replies
