Imaging (sensors)
Discuss applications using ST FlightSense Time-of-Flight sensors, ST BrightSense CMOS image sensors, and ambiant light sensors (ALS) technology. Find answers to your questions on troubleshooting, data accuracy, optimizing communication and more.
Resolved! STSW-IMG039_L4CD doesn't exist anymore!!
Hello, in the application-note(AN5851) of the VL53L4CD ToF Sensor there was a graphical tool used during the experamnet under the name "STSW-IMG039_L4CD", when i search for it now, i can't find it on ST-Website. Is there any replacment for this tool(...
AElgh by Associate III
  • 1340 Views
  • 1 replies
ToF on 3mm cover glass?
Hi, we have a project which must be equiped with 3mm thick cover glass. However, all notes and recommendations we found are about 1mm and max. 2mm. Would it be possible with a good calibration to run a ToF on 3mm glass?Which sensor would be best for ...
MHarr.9 by Associate II
  • 2677 Views
  • 4 replies
Effect of "timing butget" using VL53L1CX
I use the "short mode" and set the timing butget to 100 ms. Every second I start a new measure with VL53L1X_StartRanging. With VL53L1X_GetRangeStatus() I poll for a new measure. But when I measure the time that is needed for a range it is only 20 ms....
MKlag.1 by Associate
  • 1282 Views
I have a few questions about VL53L1CB.
1. I would like to know the release date of VL53L1CB and VL53L1CX.2. If you check the datasheet of the VL53L1CB, it is listed as the VL53L1 model, but the CB is missing. I want to know the reason. What does CB mean?Is there a datasheet dedicated to t...
sLee.401 by Associate
  • 1575 Views
  • 1 replies
