VL53L5CX less sensitive gesture recognition
SOsle.1
I would like to make a gesture recognition to be less sensitive for my application. I know that I am able to change parameters like GW_MIN_SPEED_X_MM_S, GW_MIN_VX_ON_VY, etc, but I am not exactly sure which parameters to change and how much I need to change them in order to get desired result.
John E KVAM
Less sensitive in which regard? Are you intrepreting very small hand motion as a gesture?
In our testing we tried very hard NOT to miss any gestures.
I don't think there is a knob to adjust how sensitive the algorithm is.
But if you have a use case, we can try to put it in.
  • john
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
