maximum temperature (while not operational) of VL53L0X ToF sensor
philipw
Hi everyone,
can you provide information on the highest temperature and ambient pressure the VL53L0X Time of Flight (ToF) ranging sensor can handle without being damaged? Note: this is not during operation of the sensor (operating temperature is given as -20 °C to 70 °C in the datasheet) but during the integration process into a larger system.
Thanks in advance and kind regards
Philip
Anne BIGOT
In the datasheet, you can find a section about the reflow process. (section 8.4)
In this section, you will find all the information regarding the integration process in term of temperature.
Regarding the pressure, what are you looking for ?
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised.
ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
4 REPLIES 4
Anne BIGOT
philipw
thanks for the tip to look at the reflow section, that is very helpful.
The manufacturing process of the larger system requires curing under a certain air pressure. Therefore I want to know if the sensor will survive being exposed to this pressure.
Philip
Hello Philip,
regarding pressure those are tests we are not doing.
Anne
The sensor is hollow. And it's not the pressure you should worry about, but the rate of change in pressure. The sensor will compensate, but the opening is small and it won't compensate quickly. That's one of the reasons that in the re-flow temperature profile we don't want you heating and cooling the chip rapidly.
The chip will withstand a 'reasonable pressure', but build to that pressure slowly.
We don't do tests on how much pressure it will handle, so unfortunately there you are kind of on your own.
- john
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
