2021-02-24 02:40 PM
STM32L073RZ
We are entering the BL via boot0. The STM32Cube Programmer software sees the USB port but when I try to connect, the part resets out of the bootloader.
Appreciate any ideas.
Rich
2021-02-26 05:21 AM
Hi @RSoen.1 ,
Thanks for your feedback.
Indeed, this problem is already raised and will be corrected in the next STM32CubeProgrammer release available very soon.
Hope this helps you, when your question is answered please close this topic by choosing Select as Best this will help other users find that answer faster.
Houda
2021-02-26 05:21 AM
Hi @RSoen.1 ,
Houda
2021-02-28 09:54 AM
Well I am glad it is not a bug in my code or worse yet the bootloader.
When will the next rev be released?
Are there other software tools that support the USB bootloader?
Rich
2021-02-28 01:37 PM
Hi @RSoen.1
You can use the Dfuse tool available on st.com.
Please pay attention that drivers for STM32CubeProgrammer and Dfuse are not compatibles , You need to remove manually the CubeProgrammer driver before using Dfuse.
Houda
2021-03-03 01:22 PM
I tried the dfuse tool. Converted the bin to dfu with included tool. The utility connects and I can "Upgrade" but the new code is not uploaded, still running the ld code.
2021-04-06 08:54 AM
Hello ST,
Any word on a new version of the STM32cube programmer with the USB connection reset fix?
Rich
2021-04-20 07:52 AM
Hello ST ......
