STM32CubeProgrammer can't connect in hotplug mode
nhedler
Using an STLINK-V3PWR, I can connect to the device in Normal, Under Reset, and hwRstPulse modes, but when I select Hot plug mode, I get an error "No STM32 target found." I've been tasked with trying to connect to this board without resetting it, but am at a loss about where to start with troubleshooting. I've tried changing various other configuration settings, but have not found anything that will allow hot plug connection.
KnarfB
make sure that the firmware leaves the SWD debug pins configured in SWD AF mode (which is the HW default).
Also, entering low-power modes may cause issues, see DBG_CR register.
hth
KnarfB
