Read from motor controllet vio
Paramounts
OK so total noob here with a issue, I am trying to read from an esc/motor controller  through jtag ,problem lies in the fact  that iim using St link and bluepill  and there connected throigh  sclk sdio c9nnections.so my question is how and what to do to read and write to said controller  thanks in advance
1 REPLY 1
Aziz BRIGUI
Hello @Paramounts,
Could you provide more context to the issue you're facing. We might need to change the topic to your question to give it more visibility and increase the chances to get a reply.
Are you having trouble connecting to STM32CubeProgrammmer and reading the memory of the bluepill ? Could you explain the motor control part further ?
Thanks,
Aziz
