Why isn't it possible to create a CubeMX project on L552 using Makefile "Toolchain / IDE" ?
GLebr.1
3 REPLIES 3
Khouloud ZEMMELI
Hello @GLebr.1​ ,
Thank you for your question,
In fact, the Makefile toolchain still not supported for multicortex products (including STM32L5), and there's no plan to support it for the moment, sorry for that.
I propose you to use the available Toolchain instead, such as STM32CubeIDE ��
Thanks for your comprehension,
Khouloud
GLebr.1
Hi Khouloud,
Thank you for your answer, and I understand your position. Is there a way to get informed as soon as the Makefile workflow get available ?
Best regards,
Guillaume
Yes @GLebr.1​ , I'll keep you informed once it will be supported.
You're always welcome :)
Khouloud
