Oct 4, 2023 7:34 PM UTC
Using a custom linker script with STM32CubeMX and makefile output
I use CubeMx to generate a Makefile project.
However, whenever I regenerate the code, it overwrites the linker script (STM32H743ZITx_FLASH.ld in my case).
Is there anyway to prevent CubeMx from doing this?
Thanks,
Dominic
Oct 9, 2023 9:48 AM UTC
Hello @Dominic_Valentino,
In order to stop overwriting the linker script (STM32H743ZITx_FLASH.ld) generated by CubeMx .I advise you to rename this file and specify the new name in the linker settings.
Thanks.
Mahmoud.
Oct 5, 2023 9:20 AM UTC
First let me thank you for posting and welcome to the ST Community
Can you provide please the STM32CubeMx version which you are using.
Thanks.
Mahmoud.
Oct 5, 2023 11:30 AM UTC
Hello @Mahmoud Ben Romdhane !
Yes the version number is: 6.9.1.
Thanks,
Dominic
Thanks.
Mahmoud.
Andrew Neil
Sep 26, 2024 5:52 PM UTC
