2023-10-04 12:34 PM
I use CubeMx to generate a Makefile project.
However, whenever I regenerate the code, it overwrites the linker script (STM32H743ZITx_FLASH.ld in my case).
Is there anyway to prevent CubeMx from doing this?
Thanks,
Dominic
2023-10-09 02:48 AM
Hello @Dominic_Valentino,
In order to stop overwriting the linker script (STM32H743ZITx_FLASH.ld) generated by CubeMx .I advise you to rename this file and specify the new name in the linker settings.
Thanks.
Mahmoud.
2023-10-05 02:20 AM - edited 2023-10-05 02:20 AM
First let me thank you for posting and welcome to the ST Community
Can you provide please the STM32CubeMx version which you are using.
Thanks.
Mahmoud.
2023-10-05 04:30 AM
2023-10-09 02:48 AM
Thanks.
Mahmoud.
2024-09-26 10:52 AM
