STM32H730ZB - SDRAM BANK1 wrong address
‎2024-06-10 5:41 PM
I create a new project with STM32CubeIde 1.15.1 (but same with 1.10.1)
I add SDRAM 1 - BANK 1
When I debug this project, after HAL_SDRAM_Init function in MX_FMC_Init(), I can wath the memory in MEMORY BROWSER at address 0x60000000.
But on reference manual, SDRAM should be at 0xC0000000.
I select Default mapping in Bank Mapping :
If I select bank swapped, I have my datas at 0xC0000000.
Is it a bug of STM32CubeIDE ?
Bug-report
FMC-FSMC
STM32H7 Series
‎2024-06-18 3:52 PM
Isn't 0x60000000 the NOR FLASH on the STM32H743I-EVAL board?
What about after it's finished SDRAM_Initialization_Sequence() ??
or
‎2024-06-12 4:47 AM
Hello @COSEBE ,
Thank you for bringing this issue to our attention.
I reported internally.
The internal ticket 184015 (not accessible by community users) has been opened to confirm and fix the issue.
Thank you for your contribution in STCommunity.
Kaouthar
‎2024-06-12 7:07 AM
Hi Kaouthar,
Did you manage to reproduce the problem?
Is it a known problem?
Should I continu to investigate the problem?
‎2024-06-12 7:29 AM
Hi @COSEBE ,
I reproduced the problem and I reported internally to our STM32CubeMx team for confirmation and fix.
Also, I checked FMC_SDRAM example and it works correctly. For that, I recommend you to start with this example.
I think that SDRAM Initialization sequence shared in this FAQ How to set up the FMC peripheral to interface with... - STMicroelectronics Community can help you.
I will come back to you for more details as soon as possible.
Thank you.
Kaouthar
‎2024-06-12 9:00 AM
Honestly I think this problem is compounded because the Hardware has 0 / 1 signal designations, and then you refer to SDRAM Bank 1 and Bank 2, and the SDRAM chip itself has it's own understanding of "banks", with BA0 / BA1
ie
SDNE0 / SDCKE0 -> SDRAM1 aka BANK 1 -> 0xC0000000
SDNE1 / SDCKE1 -> SDRAM2 aka BANK 2 -> 0xD0000000
Given how systemic this has become, going to hard to rationalize it now..
‎2024-06-12 9:04 AM
Well, if that, It should be on every STM32H7, but it woks with STM32H7B3.
If that, I should have wrong address 0xC0000000 / 0xD0000000 but not 0xC0000000 / 0x60000000
‎2024-06-12 9:21 AM
Well this gets into another set of issues where the H7 family has at least 3 different die and they all behave differently, have different speeds and peripherals and occasionally have incompatible AF Mux settings.
H74x/H75x
H72x/H73x
H7Ax/H7Bx
‎2024-06-18 2:50 PM
This example is on bank 2.
Do you have a example on any STM32H7 working with SDRAM on bank 1 ?
‎2024-06-18 3:20 PM
Most of the H7 DISCO/EVAL BSP indicate use of BANK2, but the world is full of examples if you search, and the implementation is pretty orthogonal..
‎2024-06-18 3:21 PM
Can you check the example on repository H7 1.11.2 on STM32H743 ?
It is on bank 2 but still showing memory on 0x60000000 in my side
