STM32F103 SMBus Communication via CubeMX
BY
Hi there,
I am a new at SMBus communication. I design a board. Board have STM32F103 MCU and BQ40Z80. I need to make a communication between STM32 MCU and BQ IC but I couldn't find parameter settings in CubeMX.
Software is STM32CubeMX Version 6.11.1
I also attached a picture that shows there is no parameter settings for SMBus.
If anyone has sample code for SMBus communication that will be helpful.
Best Regards,
BY
7 REPLIES 7
SofLit
SMBus is configurable in that menu:
PS: This is NOT an online support (https://ols.st.com) but a collaborative space. So please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help/support.
SofLit
Umm well now I understood the request ..
Meanwhile, you can also refer to that package: X-CUBE-SMBUS and AN4502 "STM32 SMBus/PMBus™ expansion package for STM32Cube™"
Need toc check internally why there is only one setting in the parameters to set for SMBus!
BY
By the way, BQ40Z80 interface is SMBus v.1.1
Before I sent first post I already installed X-CUBE-SMBUS.
Waiting for your feedback.
I recall there being examples for the SPL (pre HAL)
https://github.com/selat/stm32-smbus
Use Google, search on GitHub, heck read/review RM0008
Oh thanks. I already read that but will try to research again.
Update: the fix is planned to be fixed in the next version CubeMx 6.12.0
SofLit
FYI,
Internal Ticket 181150 has been already created for follow-up.
