STM32 Cube MX and IAR
Jet1
Hi All,
I am trying to run a code with NUCLEO-U575ZI-Q The tool chain/ IDE is  EWARM but the unable to select the latest version of IAR(9.50) The option is available only until IAR version 8.5. When I select generate code and select open project the IAR version 8.5 IDE opens and I will not be able to debug the firmware
I am able to debug the run the firmware  when I select open folder  and run EWARM from latest version of IAR(9.50)
Is there a way to be able to see the latest version on STM Cube MX  ?
Guru
Probably just isn't supported yet.
v8.50 is the latest supported version per the release notes.
rn0094-stm32cubemx-release-6120-stmicroelectronics.pdf
Surely you can open up projects created for v8.5 in newer versions. All IDEs have good backwards compatibility support, especially for the last few versions.
Pavel A.
Evangelist III
Open the project in the latest IAR 9.x and upgrade it (the project) when prompted.
