keil program with nucleo stm32xubemx
meriarajagukguk
if i have
 int angka_test = 10;
int a;
while (1) {
output = output_start + ((output_end - output_start) * (angka_test - input_start)) / (input_end - input_start);
a = angka_test;
__HAL_TIM_SET_AUTORELOAD(&htim2, output); }
why 'a' if i seee form watch is 0, but angka_test=100, help me
Andrew Neil
Please see the posting tips for how to properly post source code:
https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/ta-p/575228
It should look something  like this:
int a;
while (1) {
   a = angka_test;
@meriarajagukguk wrote:
why 'a' if i see from watch is 0, but angka_test=100, help me
Perhaps provide a screenshot of how you're seeing this, and a detailed description of how you get there?
Note that Keil is a 3rd-party products - nothing to do with ST - so you really need to be asking Keil about specific issues with their tool:
https://community.arm.com/support-forums/f/keil-forum
Two things to note:
  1. Optimisation: in the code shown, you never use the value of a - so it's likely to have been optimised away;
  2. Understand how Keil updates its "Watched" values - maybe what you're seeing is just "out of date", because the display hasn't updated?
Andrew Neil
int a;
while (1) {
   a = angka_test;
Two things to note:
meriarajagukguk
big thanks to your help
