2019-10-22 10:35 PM
On my i7-4Core Notebook with SSDs and 32GByte RAM,
newest Java Version:
Starting Program: 5-7 Minutes
Open existing Project (F767zit, All 144 Pins used): 10 Minutes
Deactivating TIM7: 1-2 Minute
Changing Pin Function: 1-2 Minute
Generating Code is normal in timing.
Is there any Solution to this. CubeMx 5.3.0 was perfect in time behavior.
regards
Knut
2019-10-24 9:37 AM
Hi Knut,
We did not get such timings when validating the CubeMx 5.4.0 on various platforms.
I guess the problem is 100% reproducible, can you please confirm ?
Can you please also share the Java WM provider you are using, we know some JVM are slowr than other, but not in the range you mention.
Jérôme
2019-10-29 7:54 AM
Hello, sorry for my late reaktion.
I have updated JRE to Version 1.8.0.231. Now the CubeMX starts faster but loading a project takes 7 to 10 minutes again.
Changing setting (e.g. setting I2C1 from dissabled to I2C takes 2 -3 minutes.
best regards
Knut
2019-10-29 8:12 AM
Hi Knut,
Are you using Oracle JVM or other one (OpenJDK or Correto) ?
Are you using 64 bits JVM and not a 32 bits one ?
Last but not least, if the problem is specific to a CubeMX project you are editing, can you please share the associated ioc file ?
Kind regards
Jérôme
