2021-03-16 06:31 AM
Doing a "git diff" on my project IOC file notably highlights these changes:
-Mcu.Pin6=PA2
-Mcu.Pin7=PA3
+Mcu.Pin6=PA0
+Mcu.Pin7=PA1
Looking at the IOC file, I do not think that these Mcu.PinXXX parameters define the actual pin name associated with a physical pin number.
So I am wondering what these Mcu.PinXXX parameters represent. And an even more important question: where are all STM32CubeMX IOC file parameters documented by ST? Googling them leads to no results.
Thanks!
2021-03-16 07:10 AM
Hello @JLemi ,
Thanks for your question,
In fact, the Mcu.PinX=PA2 represents the assignment order of this pin to the signal chosen, for example if you create a new empty project then you have set the PA2 to GPIO_Output , you will get Mcu.Pin0=PA2 in your ioc file, etc..
Actually, there is no document that explains these details, but don't hesitate to give your suggest about this regards under the Idea Zone, we even encourage you to come up with any idea that suits you and that you think is missing in ST Tools, your ideas are always interesting and welcome :)
Hope my answer helped you, When your question is answered, please close this topic by choosing Select as Best. This will help other users find that answer faster.
Thanks for your contribution, Khouloud
2021-03-16 07:10 AM
Hello @JLemi ,
2021-03-16 07:20 AM
Many thanks. The naming "Mcu.PinXXX" seems rather poorly chosen for what you describe. Best regards.
