2015-12-06 3:58 AM
Hi. I am trying to create stm32f401 code using matlab. I can install the mat_target file and configure simulink code generator. My problem is that when i am trying to build my project, CubeMX does not start and the matlab is busy for many hours. In matlab diagnostic viewer the last message i get is that
''♯♯♯ Open STM32CubeMX for configuration and project code generation. Start command: ''C:\Program Files\STMicroelectronics\STM32Cube\STM32CubeMX\STM32CubeMX.exe'' -q ''D:\Electronics\STM32F401\Projects\Matlab Test2\Matlab Test\.script''
'' I am using matlab 2014a. Any help please? #stm32 #cubemx #matlab2015-12-07 4:46 AM
It is certainly because of Java version installed. you must install Java 64bits. Regards Pascal
