Issue when using CubeMX with Atolli
SZoha
I am setting the Nucleo-H743ZI board with STM32 CumbeMX and when trying to compile the code with Atolli I am getting ..\Drivers\CMSIS\DSP\Source\BasicMathFunctions\arm_dot_prod_q7.c:29:22: fatal error: arm_math.h: No such file or directory
I see other users having this issue for long time but didn't find a clear working solution for this issue.
I added some packs (not sure which one is needed but the problem still exists).
The .IOC is attached.
0 REPLIES 0
