Is their any tool (or option) in STM Cube-IDE to generate a document that contains all the gpio, peripherals and clock configuration for a project.
DDosi
Andreas Bolsch
Lead II
File->Generate Report ?! The *.pdf is more exhaustive than the *.txt.
Andreas Bolsch
Lead II
Thank you for your help.
Found the Generate Report option in Project-> Generate Report.
Both PDF and txt are generated together.
I am using STM Cube IDE Version 1.9.0
with STM Cube MX Version: 6.5.0
