2022-12-08 9:47 AM
I've created a new project and it seems like code wasn't generated as it should.
Modified only clock configuration and added FREERTOS to my project.
I think here tasks should be started, instead I have duplicate for header:
Is it normal, have I missed something?
Best regards,
Krzysztof
2022-12-09 1:55 AM
Hello @Krzysztof Woźniak
Thank you for having reported.
I assume this is the exact same issue already reported to the development team and tracked by the Ticket 140318 and that will be fixed as soon as possible.
Kind regards
Ghofrane
2022-12-08 10:19 AM
There are some more with the same problem. It was written several times.
I have found a work around.
So you could see to my question "What happens to FreeRTOS code generation?"
2022-12-08 10:27 AM
Thanks for reply. Indeed that's a duplicate
2022-12-09 1:55 AM
Kind regards
Ghofrane
