Incorrect code generation
KWoźn.1
I've created a new project and it seems like code wasn't generated as it should.
Modified only clock configuration and added FREERTOS to my project.
I think here tasks should be started, instead I have duplicate for header:
0693W00000WKa7zQAD.pngIs it normal, have I missed something?
Best regards,
Krzysztof
Ghofrane GSOURI
Hello @Krzysztof Woźniak​
Thank you for having reported.
I assume this is the exact same issue already reported to the development team and tracked by the Ticket 140318 and that will be fixed as soon as possible.
Kind regards
Ghofrane
3 REPLIES 3
TManiac
There are some more with the same problem. It was written several times.
I have found a work around.
So you could see to my question "What happens to FreeRTOS code generation?"
KWoźn.1
Thanks for reply. Indeed that's a duplicate
Ghofrane GSOURI
Kind regards
Ghofrane
