I2S "Half-Duplex Master" Transmission Mode - "Mode Master Recive" does not work.
TDerk.1
/* USER CODE END Header */
#include "main.h"
#include "i2s.h"
#include "gpio.h"
#include <stdio.h>
#include "SEGGER_RTT.h"
#include "debug_helper.h"
#define HAL_TIMEOUT     1000
#define MIC_BUFF_SIZE   256
int32_t mic_buff[MIC_BUFF_SIZE];
void sph0645_test(void)
  HAL_StatusTypeDef hal_st;
  while(1)
    hal_st = HAL_I2S_Receive(&hi2s2,
                            (uint16_t*)mic_buff,
                            MIC_BUFF_SIZE,
                            HAL_TIMEOUT);
    if(hal_st != HAL_OK)
      printf("HAL_I2S hal_st=%i\n",hal_st);
      HAL_Delay(5000);
    for(uint32_t i=0; i<MIC_BUFF_SIZE; i++)
      printf("\nM="); printBits(sizeof(mic_buff[i]), &mic_buff[i]); HAL_Delay(10);
/* USER CODE END Includes */
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  MX_GPIO_Init();
  MX_I2S2_Init();
  /* USER CODE BEGIN 2 */
  SEGGER_RTT_ConfigUpBuffer(0, NULL, NULL, 0, SEGGER_RTT_MODE_NO_BLOCK_TRIM);
  //SEGGER_RTT_WriteString(0, "SEGGER RTT START\r\n\r\n");
  printf("printf ok\r\n");
  sph0645_test();
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
  * @retval None
void SystemClock_Config(void)
  /** Supply configuration update enable
  HAL_PWREx_ConfigSupply(PWR_LDO_SUPPLY);
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE0);
  while(!__HAL_PWR_GET_FLAG(PWR_FLAG_VOSRDY)) {}
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLM = 1;
  RCC_OscInitStruct.PLL.PLLN = 78;
  RCC_OscInitStruct.PLL.PLLP = 2;
  RCC_OscInitStruct.PLL.PLLQ = 8;
  RCC_OscInitStruct.PLL.PLLR = 2;
  RCC_OscInitStruct.PLL.PLLRGE = RCC_PLL1VCIRANGE_3;
  RCC_OscInitStruct.PLL.PLLVCOSEL = RCC_PLL1VCOWIDE;
  RCC_OscInitStruct.PLL.PLLFRACN = 0;
    Error_Handler();
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2
                              |RCC_CLOCKTYPE_D3PCLK1|RCC_CLOCKTYPE_D1PCLK1;
  RCC_ClkInitStruct.SYSCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_HCLK_DIV2;
  RCC_ClkInitStruct.APB3CLKDivider = RCC_APB3_DIV2;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_APB1_DIV2;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_APB2_DIV2;
  RCC_ClkInitStruct.APB4CLKDivider = RCC_APB4_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_4) != HAL_OK)
    Error_Handler();
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
  * @brief  Period elapsed callback in non blocking mode
  * @note   This function is called  when TIM2 interrupt took place, inside
  * HAL_TIM_IRQHandler(). It makes a direct call to HAL_IncTick() to increment
  * a global variable "uwTick" used as application time base.
  * @param  htim : TIM handle
  * @retval None
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
  /* USER CODE BEGIN Callback 0 */
  /* USER CODE END Callback 0 */
  if (htim->Instance == TIM2) {
    HAL_IncTick();
  /* USER CODE BEGIN Callback 1 */
  /* USER CODE END Callback 1 */
I have connected SPH0645 to STM32H750VBT on I2S2 port. Mode "Half-Duplex Master" Transmission Mode - "Mode Master Recive".
Oscillograms of CLK WS & DATA signals on processor pins correspond to expectations.
HAL_I2S_Receive () function - fills the input buffer with zeros.
In the "Full-Duplex Master" mode, the HAL_I2S_Receive () function fills the input buffer with correct data.
The code was created by STM32Cube MX. Connected in accordance with STM32Cube MX.
Test project here: https://github.com/derkachtf/I2S2-on-STM32H750VBT
3 REPLIES 3
Isn't pin swapping set? Read out the I2S registers and check against the working case.
TDerk.1
0693W000008wGX4QAM.pngI re-solder the contact as required by STM32Cube MX.
STM32Cube MX offers pin SDO for Master Receive mode.
But I think he should suggest and configure the SDI pin !
I don't know what the Cube/HAL functions do, I don't use Cube/HAL. They may cause the pin swap to be activated. Read the SPI/I2S chapter in RM, then read out the SPI/I2S registers for both cases and compare/check/post them.
