2022-05-24 12:13 PM
I'm trying to use the timer interrupt to blink some LEDs while my main is running, but when I run the code I can't achieve the interruption.
2022-06-02 08:19 AM
Hello @Fealvares ,
Sorry for the late reply,
Please check UM1816 Description of STM32L1 HAL and low-layer drivers. Section 43 describes HAL TIM Generic Driver.
I hope this helps :smiling_face_with_smiling_eyes:
If your issue is solved, please close this post by clicking the "Select as Best" button. This will help other members of the community find this response more quickly :)
Sara.
2022-05-27 08:53 AM
Hello @Fealvares ,
Thanks for your feedback,
Could you please share your ioc file to help us reproduce the issue ?
Sara.
2022-05-27 09:18 AM
Hi @Sara BEN HADJ YAHYA ,
Acutally I'm a beginner working with STM Tools. With a co-worker help I figure out that was a function missing in my code.
HAL_TIM_Base_Start_IT(&htimX);
But when I searched for how to configure the time interruptions, I couldn't find any code using this line.
Is there any kind of guide that would help me to use the HAL libs?
Att,
Felipe.
2022-06-02 08:19 AM
Hello @Fealvares ,
Sara.
