Hi ,
I find the H757XIHx EVB can not debug . I generated the project from CubeMX . In CubeMX , I select the Debug model serial Wire ,but It can only attach to the Cortex-M7,so it can not debug M4 core.
What should I do ?
Thank you very much!
Options
2020-04-08 09:30 PM
Options
2020-05-07 06:49 AM
Hello @FWANG.1
Could you please share your ioc file to check the issue.
Best regards,
Nesrine
Options
2020-05-12 10:26 AM
Hi Nesrine,
Thanks for your support!
I have solved this problem ,that is not the Cube's problem.
I updata the STLink driver and solved this issue.
I can debug both core now.
Thanks again for your reply!
Best regards,
Fei
