H743BI: Can't setup CPU clocks above 200 MHz
Kamil Duljas
Senior III
try setup clock above 200 Mhz (try for revision Y and V) and get error:
Error has occured also if you try set D1PRE set above 200 Mhz:
Dudo
Foued_KH
Hello @kamil Duljas​ ,
You can try :
_legacyfs_online_stmicro_images_0693W00000bjrD6QAI.pngIt's fine now :
Foued
Foued_KH
You can try :
Foued
Kamil Duljas
Senior III
Ok , thanks. It is not intuitve enough.
Dudo
