H743BI: Can't setup CPU clocks above 200 MHz
‎2023-05-11 1:30 AM - edited ‎2023-11-20 5:43 AM
try setup clock above 200 Mhz (try for revision Y and V) and get error:
Error has occured also if you try set D1PRE set above 200 Mhz:
- Labels:
RCC
STM32CubeMX
STM32H7 Series
‎2023-05-11 1:40 AM - edited ‎2023-11-20 5:44 AM
Hello @kamil Duljas​ ,
You can try :
It's fine now :
Foued
You can try :
It's fine now :
Foued
‎2023-05-11 1:48 AM
Ok , thanks. It is not intuitve enough.
