Do Changes to IOC file propagate to the code?
GSeme.1
I have a project and I need to change the pin assignment for peripherals. If I open the .ioc file and make the changes will those pin assignment changes propagate into the code when I re-build it?
Guru
You need to re-generate the code in order for IOC changes to make it to source code.
GSeme.1
Never mind.
Guru
