Bea_12
Jan 27, 2025 12:29 PM UTC
Main.h is not found
I generated the code in CubeMX and opened it in VSCode. However, I cannot run the code because VSCode cannot find main.h. I'm not sure why this is happening. I've generated the code twice, but the problem persists. The main.h file is located in the Core > Inc folder, and main.c is in the Core > Src folder. Does anyone know what might be causing this issue? Thanks!
Andrew Neil
Andrew NeilBest answer
Jan 27, 2025 12:49 PM UTC
If it's not finding the headers, that means your Include Paths need fixing - these are what tell the compiler where to find header files.
https://labs.dese.iisc.ac.in/embeddedlab/vscode-include-paths/
https://code.visualstudio.com/docs/cpp/c-cpp-properties-schema-reference#:~:text=includePath%20An%20include%20path%20is%20a%20folder%20that%20contains%20header%20files%20(such%20as%20%23include%20%22myHeaderFile.h%22)%20that%20are%20included%20in%20a%20source%20file
KnarfB
Jan 27, 2025 12:40 PM UTC
Did you import the project and open the folder? Here are instructions:
How to use VS Code with STM32 microcontrollers - STMicroelectronics Community
hth
KnarfB
Bea_12
Bea_12Author
Jan 27, 2025 12:48 PM UTC
Yes, I followed the instructions, but I have the feeling that something might be off with the settings or something else. Is there something I might need to adjust?
Andrew Neil
Karl Yamashita
Jan 28, 2025 7:22 AM UTC
upload your ioc file
If a reply has proven helpful, click on Accept as Solution so that it'll show at top of the post.CAN Jammer an open source CAN bus hacking toolCANableV3 Open Source
Bea_12
Bea_12Author
Jan 28, 2025 2:18 PM UTC
It seems like I've resolved one of the issues by changing some settings in STM32CubeMX. However, the main.c and main.h files are still incorrect. No matter what I change, the files remain problematic. Additionally, I forgot to install STM32CubeCLT, but that hasn’t affected anything else so far. I do not know what i could change that my program works. Does anyone know please explain it to me.
Andrew Neil
Jan 28, 2025 2:25 PM UTC
Excellent - what settings did you change?
Please 'Mark as solution' the post which resolved the issue:
https://community.st.com/t5/community-guidelines/help-others-to-solve-their-issues/ta-p/575256
That's a new question - please start a new thread for that, then post a link here to that new thread.
In your new thread, you'll need to give more details for people to be able to help you - see: How to write your question to maximize your chances to find a solution
Andrew Neil
Feb 12, 2025 9:27 AM UTC
