2020-09-01 1:28 PM
CubeMX will not correctly re-generate code after changing STM firmware versions.
I want to be able to modify my project's version of STM firmware throughout the course of development. For example, to pickup any upcoming bug fixes, or to point to a patched version. I also want to include STM FW by reference in our projects to reduce code duplication.
Here are the steps to reproduce this issue:
// test1.ioc
// I believe this represent's the greyed-out setting in CubeMX (above where we can specify a custom firmware path). So this doesn't seem to be cause for concern.
8:ProjectManager.FirmwarePackage=STM32Cube FW_F4 V1.25.0
// .cproject
// This appears to be the significant problem
214: <option id="com.st.stm32cube.ide.mcu.gnu.managedbuild.option.defaults.1516957908" superClass="com.st.stm32cube.ide.mcu.gnu.managedbuild.option.defaults" value="com.st.stm32cube.ide.common.services.build.inputs.revA.1.0.3 || Release || false || Executable || com.st.stm32cube.ide.mcu.gnu.managedbuild.toolchain.base.gnu-tools-for-stm32 || STM32F413ZHTx || 0 || 0 || arm-none-eabi- || ${gnu_tools_for_stm32_compiler_path} || ../Core/Inc | /home/miles/STM32Cube/Repository/STM32Cube_FW_F4_V1.25.0/Drivers/STM32F4xx_HAL_Driver/Inc | /home/miles/STM32Cube/Repository/STM32Cube_FW_F4_V1.25.0/Drivers/STM32F4xx_HAL_Driver/Inc/Legacy | /home/miles/STM32Cube/Repository/STM32Cube_FW_F4_V1.25.0/Drivers/CMSIS/Device/ST/STM32F4xx/Include | /home/miles/STM32Cube/Repository/STM32Cube_FW_F4_V1.25.0/Drivers/CMSIS/Include || || || USE_HAL_DRIVER | STM32F413xx || || Drivers | Core/Startup | Core || || || ${workspace_loc:/${ProjName}/STM32F413ZHTX_FLASH.ld} || true || NonSecure || || secure_nsclib.o || " valueType="string"/>
// .cproject
+ <listOptionValue builtIn="false" value="/home/miles/STM32Cube/Repository/STM32Cube_FW_F4_V1.25.0/Drivers/STM32F4xx_HAL_Driver/Inc/Legacy"/>
+ <listOptionValue builtIn="false" value="/home/miles/STM32Cube/Repository/STM32Cube_FW_F4_V1.25.0/Drivers/STM32F4xx_HAL_Driver/Inc"/>
System info:
2020-10-19 8:59 AM
Hello @Miles
Thanks for the feedback,it will be internally checked.
Best Regards,
Nesrine
2020-10-20 9:22 AM
Hello @Miles
Thanks for your post. I have raised your feedback internally to be reviewed and treated accordingly to the priority. We will give you an update as soon as possible.
Thanks for your contribution.
Best regards,
Nesrine
