[BUG] Wrong definition vportFree in FATFS file "ffconf.h" generated by new CubeMX 5.5.0
SStor
Hello STM-Team,
new CubeMX 5.5.0 generates a wrong standard definition for ff_free in file "ffconf.h":
(if FATFS and FreeRTOS are used)
#define ff_free  vportFree
Correct syntax with upper case P would be:
#define ff_free  vPortFree
Could you verify this problem?
Thank you!
1 REPLY 1
Khouloud ZEMMELI
​Hello @SStor​ ,
Thanks for the feedback, you're right, issue will be fixed in the next release.
Best Regards,
Khouloud.
