ADC Clock and Conversion Time question
‎2024-08-20 7:09 PM
Hi, I'm giwon KIM in South Korea.
I'm using NUCLEO-401RE board.
In STM32F401RE datasheet and reference manual, It is said to be capable of operating at up to 30 MHz.
So its conversion time was set by calculating (12+3) / 30 MHz = 500 nsec.
I generated a sine wave of 250Hz and advertised it, but as calculated, I had to get 8000 samples per cycle, but I only got about 1300.
Is there a reason for this?
Below is actually a waveform drawn with Excel by acquiring a cycle sample.
And this is my ADC1 init function.
* @brief ADC1 Initialization Function
* @param None
* @retval None
static void MX_ADC1_Init(void)
/* USER CODE BEGIN ADC1_Init 0 */
/* USER CODE END ADC1_Init 0 */
ADC_ChannelConfTypeDef sConfig = {0};
/* USER CODE BEGIN ADC1_Init 1 */
/* USER CODE END ADC1_Init 1 */
/** Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
hadc1.Instance = ADC1;
hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV2;
hadc1.Init.Resolution = ADC_RESOLUTION_12B;
hadc1.Init.ScanConvMode = DISABLE;
hadc1.Init.ContinuousConvMode = ENABLE;
hadc1.Init.DiscontinuousConvMode = DISABLE;
hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
hadc1.Init.NbrOfConversion = 1;
hadc1.Init.DMAContinuousRequests = DISABLE;
hadc1.Init.EOCSelection = ADC_EOC_SEQ_CONV;
if (HAL_ADC_Init(&hadc1) != HAL_OK)
Error_Handler();
/** Configure for the selected ADC regular channel its corresponding rank in the sequencer and its sample time.
sConfig.Channel = ADC_CHANNEL_0;
sConfig.Rank = 1;
sConfig.SamplingTime = ADC_SAMPLETIME_15CYCLES;
if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN ADC1_Init 2 */
/* USER CODE END ADC1_Init 2 */
If you have any question, please ask me.
Thank you.
- Labels:
ADC
STM32F4 Series
‎2024-08-20 7:21 PM
Conversion time will be 15 + 12 ticks in this case. 15 for sampling and 12 for conversion. With a 30 MHz clock, this is 900 ns
A 250 Hz sine wave period is 4 ms.
4 ms / 900 ns = 4444.
So why is yours different? Perhaps show your code.
- What is your ADC clock? Show your clock setup.
- Are you using continuous ADC conversion to a buffer using DMA? It's not going to work well with polling.
‎2024-08-20 7:25 PM
12 + 15 / 30 MHz = ?
‎2024-08-20 10:15 PM
HI,
I modified my code and settings.
* @param None
* @retval None
hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV4;
Error_Handler();
sConfig.Rank = 1;
sConfig.SamplingTime = ADC_SAMPLETIME_3CYCLES;
Error_Handler();
The output sine waveform is 250Hz as it is, and how many samples should be produced at this time?
My calculation is (12+3) / 84MHz = 22400, But if you sample one cycle, there are about 13,000.
DMA is not in use and operates in polling mode.
Thank you.
‎2024-08-21 12:14 AM
ADCCLK is shown in the Datasheet like this.
If I set APB2 to 60Mhz and clock divide to 2, is it correct that ADC operates at 30MHz?
‎2024-08-21 5:40 AM
So that's your problem. The chip takes time to run code, don't expect to get 5.6 Msps in polling mode.
‎2024-08-21 4:37 PM
I understand what you're saying. I'll have to approach it in a different way.
Thank you.
