Unable to upload my code using Serial Wire Debug
vbk22398
  I am trying to upload my code using ST Link(SWD)into a custom board with an STM32 Core. I am using serial wire debug for programming. So I am getting the above shown error messages. If anyone have come across this issue, please help me resolve it.
 I tried uploading the code using STM Cube Programmer also. I am getting the above error.!
23 REPLIES 23
Guru
Perhaps pins are not wired up correctly. Can you share a schematic? How is the board connected to the programmer specifically?
Looks like it's detecting a voltage. That's good.
Focus on your hardware implementation,  doesn't appear viable.
Check power, especially VDDA/VSSA
What STM32? The make a handful of different ones, with different expectations.
I tried programming the custom designed board using
i.) an external ST-LINK and also
ii.) using the debugger IC in the evaluation board(STM32L496ZGT6).
Both gave the same error as i mentioned in the previous posts.
NOTE:
I am able to program an Evaluation board without using the On-chip debugger IC by using an external ST-LINK. But not able to do the same with the custom designed board. Not able to find the underlying cause.!
In the debugger configuration I am able to detect the IC of the custom board. I am using Evaluation version debugger IC of STM32L496ZG to program a STM32F423RH. I am able to detect this IC when I change the setting to Segger J Link. I dont know why this happens.
LCE
Principal
I think the SWD interface also needs NRST.
Not sure though... until now I only used the complete flash adapter, incl. VCC and "GND detect".
So, what's the minimum pinning to flash (any?) STM32 via SWD?
STM32 via SWD
I am also attaching the gdbserver_log. Kindly if anyone can infer from it and help the concern, it'll be very helpful. Thanks in advance 🙂
LCE
Principal
I just checked some other posts, just to make sure that my next STM32 design will be programmable with its 5-pin SWD connector...
It seems that ST-Link needs the STM's supply voltage, NRST is only needed if the SWD pins are used for other purposes.
What's going on here? VCAP should only have the capacitor to ground. If you don't load R2, this should work.
Why does VSS_3 have a resistor to ground? It'll probably work, but doesn't make a lot of sense to me.
I don't see any other issues, although you don't show VDDA generation. Assuming that's fine.
SWD does not need VCC or NRST, but they can be useful to have.
 sir what should i do?
