2021-09-26 05:52 AM
I have a project created by STM32CubeIDE 1.7.0. Its now impossible for me to change the device configuration, e.g. adding a new peripheral or change anything in a defined peripheral. The device configuration seems to work, but the code generator does not change anything in the source files. It used to work, so any ideas?
2021-09-26 06:52 AM
Ok, got it. The project is located in a Dropbox folder, and apparently the configuration tools don't like it when Dropbox is syncing. So, in order to change the configuration I need to pause syncing for the duration. BTW, Microsoft Visual Studio also doesn't like Dropbox syncing.
2021-09-26 06:52 AM
