No ST-LINK detected, Please connect ST-LINK and restart the debug session.
‎2023-07-07 12:07 AM
Dear Sir/Mam,
I am facing an issue while using ST-Link V2 in CUBEIDE, it is not detecting and getting an error. but I am able to flash the program in to MCU using cube Programmer.
I also updated ST link drivers. I install every thing in proper manner but not able to flash through CUBEIDE.
While I am using different laptop then it is working fine with same setting, I am not able to understand why it is?
I tried many method but still showing (No ST-LINK detected Please connect ST-LINK and restart the debug session.)
I have installed all the components in the default directories.
I'm really glad for any suggestion on my issue.
Thanx in advance.
Thanks & Regards
N.Anwar
- Labels:
STM32G0 Series
‎2023-07-07 12:12 AM - edited ‎2023-07-07 12:12 AM
What's board you use? Maybe used wrong usb port on your board :)
‎2023-07-07 12:40 AM
You dont describe version IDE, but some boards stlink require manual upgrade gdbserver part in IDE.
Or your pins is used and config need change connect under reset.
