Hi, I hope I hit the correct subforum. I cannot update STM32CubeIDE to version 1.8.0. When trying to update, I get the following error message:
AAnth.1
An error occurred while collecting items to be installed
session context was:(profile=STM32CubeIDE, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,com.st.stm32cube.common.mx,6.4.0.202111222105
No repository found containing: osgi.bundle,com.st.stm32cube.common.mx.oss,6.4.0.202111222105
No repository found containing: osgi.bundle,com.st.stm32cube.common.mx.stinsider,6.4.0.202111222105
No repository found containing: osgi.bundle,com.st.stm32cube.common.projectcreation,2.1.0.202111231620
No repository found containing: osgi.bundle,com.st.stm32cube.common.projectcreation.ui,2.0.100.202108020651
No repository found containing: osgi.bundle,com.st.stm32cube.ide.common.services,2.1.0.202111231620
No repository found containing: osgi.bundle,com.st.stm32cube.ide.common.services.adapted,2.1.0.202107290805
No repository found containing: osgi.bundle,com.st.stm32cube.ide.common.services.mx,2.1.0.202107290805
No repository found containing: osgi.bundle,com.st.stm32cube.ide.documentation,2.0.100.202111181618
No repository found containing: osgi.bundle,com.st.stm32cube.ide.jre.win64,2.0.100.202110150814
No repository found containing: osgi.bundle,com.st.stm32cube.ide.mcu.analytics,2.1.0.202110260719
No repository found containing: osgi.bundle,com.st.stm32cube.ide.mcu.build,2.0.100.202110191607
No repository found containing: osgi.bundle,com.st.stm32cube.ide.mcu.build.ui,2.1.0.202110191607
No repository found containing: osgi.bundle,com.st.stm32cube.ide.mcu.converters,2.0.100.202111030832
No repository found containing: osgi.bundle,com.st.stm32cube.ide.mcu.debug.dsf,2.0.100.202110070622
No repository found containing: osgi.bundle,com.st.stm32cube.ide.mcu.debug.jlink,2.0.100.202110210915
No repository found containing: osgi.bundle,com.st.stm32cube.ide.mcu.debug.launch,2.0.100.202111231620
No repository found containing: osgi.bundle,com.st.stm32cube.ide.mcu.debug.openocd,2.0.100.202111151130
No repository found containing: osgi.bundle,com.st.stm32cube.ide.mcu.debug.stlink,2.1.0.202110211201
No repository found containing: osgi.bundle,com.st.stm32cube.ide.mcu.debug.swv,2.1.0.202111041113
AND SO ON...
Markus GIRDLAND
Hello there!
Make sure that the connection is set up properly and not blocked by a firewall or anti-virus software etc.
If it's still a problem you can try to download the stand-alone installer for 1.8.0 on the st.com website. It's available here.
You can have multiple versions of CubeIDE installed at the same time without issue, just make sure that you have a different workspace for each version.
AAnth.1
Hi, thank you. I think I will have to download a new version of STM32CubeIDE. Even when the firewall or antivirus are disabled, I get the error warning.
Thanks though.
Best regards,
