Good afternoon. I tried to check your example OpanAMP_TTY_echo together with the ssh-t ttyRPMSG0 command after trying to execute the ssh-t ttyRPMSG0 command, the terminal responds Error resolving ttyRPMSG0 port 22 Temporary failure in name resolution Why?
Vlaty.1
Senior
Good afternoon. I tried to check your example OpanAMP_TTY_echo together with the ssh-t ttyRPMSG0 command after trying to execute the ssh-t ttyRPMSG0 command, the terminal responds Error resolving ttyRPMSG0 port 22 Temporary failure in name resolution Why? What did I do wrong? Sincerely, Alexander
2 REPLIES 2
Olivier GALLIEN
Hi @Vlaty.1​
Can you better explain what you are trying to achieve ?
ttyRPMSG0 is used to exchange message/data between A7 and M4.
From where did you try to connect with ssh-t ttyRPMSG0 ?
Olivier
Olivier GALLIEN
Good morning. Thanks for the help. But when trying to contact stm32mp157a-DK1 (), there is no communication channel again. Device on com 3, idle/busy status .Address 192.163.1.7 once green . This usually worked stably. Sincerely, Alexander. пн, 26 окт. 2020 г. в 19:23, ST Community :
