2020-10-27 1:32 PM
Hi guys,
I'm designing a custom board with STM32MP157C using the MB1263 board as reference.
The MB1263 reference design shows the VDD_OTP pin tied to VDD, which is 3V3 for that particular board.
My custom board uses VDD = 1V8 instead of 3V3.
Should I tie the VDD_OTP to 3V3 or 1V8?
I could not find any reference on VDD_OTP recommended voltage.
Thank you in advance.
2020-10-28 1:27 AM
VDD_OTP does not exist in product documentation, board schematics were done on a very first engineering sample silicon where this pin was present for test purposes.
On final products, there is no VDD_OTP pin, OTP programming voltage is internally tied to VDD. The former VDD_OTP pin you can see on some schematics is now a VDD pin in product datasheet.
So, no worries, OTP could be programmed with either VDD = 1.8 or 3.3V.
Regards.
2020-10-28 1:27 AM
Regards.
