STM32 MPUs Products and hardware related
Ask questions and find answers on STM32 microprocessors, including hardware, power, DRAM, flashing, interfacing, device tree, and peripherals.
Resolved! Qt SDK build failed
Hi All -I was attempting to build the Qt example images for the DK2, following the wiki directions here:https://wiki.st.com/stm32mpu/wiki/How_to_build_and_use_an_SDK_for_QTI got to the step where it's building the SDK, after compiling the image succe...
MMedv by Associate II
  • 11994 Views
  • 18 replies
uInitrd not found openstlinux
hi, I have been working on compiling an openstlinux image with yocto, when compiling the image with bitbake it does not show me any error, but when mounting the image on the SD card it shows me the error that it cannot find "uInitrd", check in the ...
FPini.1 by Associate II
  • 1743 Views
  • 1 replies
Resolved! Compile Device Tree
Hi all,What is the most correct and easiest way to generate dtb for the STM32MP1?I tried following this : https://wiki.st.com/stm32mpu/wiki/How_to_compile_the_device_tree_with_the_Developer_PackageLooks way complicated and I get below error :/opt/st/...
NPal.2 by Senior
  • 7646 Views
  • 13 replies
Can't control a second PWM from sysfs (TIM4_CH4 / PD15), although I can control (TIM1_CH1 / PE9). (on stm32mp157c-dk2)
Hello,I try to make a simple PWM work on PD15 with TIM4_PWM4, wich normally output the PWM on D6, the 6th pin of CN14. I followed example of https://wiki.st.com/stm32mpu/wiki/PWM_overview as I only need two PWM controlled with sysfs (the first beeing...
BJola.1 by Associate II
  • 1502 Views
  • 1 replies
Setting System registers
I am using STM32MP157C and as part of the project i am trying to configure the hardware by enabling and disabling certain security features(tamper detection,trust zones,rd and wr protection etc)I would like to know if there is a way to access the sys...
KS.2 by Associate III
  • 1308 Views
  • 3 replies
