2022-11-10 10:58 AM
Hi.
I using stm32f767zgt6.
there is no problem until I add 4 or more widget on the screen:
the original screen:
the screen:
in the middle of scan (?) it goes to hard fault handler!
what is the problem?
I test it in keil, cubeIDE, touchgfx 4.20, 4.19, 4.18, CubeMX 6.5, 6.6.1 but results were same!!
2022-11-10 11:45 AM
Hardfault is named hard because report hardware fail.
Maybe SDRAM is first , second clocking.
Try move slider down if is source for trouble...
2022-11-10 10:20 PM
May latest hard faults came from some bad memory declarations and inequalities between linker file and declared memory size in c file.
