Change the name of the project in STM32CUBEIDE
Damiano
it is possible to change the name of the project in STM32CUBEIDE?
The name is set by TouchGFX designer software by default.
When i tried to rename in STM32CUBEIDE i got an error.
Martin KJELDSEN
Chief III
Edit the name in the .project file. By default, the name is the root path of the application, but can be changed.
<?xml version="1.0" encoding="UTF-8"?>
<projectDescription>
	<name>new_name</name>
	<comment/>
	<projects>
	</projects>
5 REPLIES 5
Martin KJELDSEN
Chief III
	<comment/>
	<projects>
	</projects>
Thanks, it works ��
Great! :)
PJR42
That looked like the perfect solution ... until I tried it and nothing happened ��
Using 1.5.1. Am I missing something?
Just figured out how to do it but couldn't delete my post.
You have to do it before importing the project and change the folder name as well.
