How can i save the data entered from keyboard on flash memory?
BGünç.1
I want to save the text entered from keyboard (widget) . How can i do that? Or how can i access the address of the text entered from keyboard? Could someone help me?
MM..1
Chief III
Save to use after poweroff, or save for actual runtime?
Firstly, thanks for the response. After poweroff. I save the text in a box. Then, after i entered the text and after poweroff, i want to still be there.
Then you need solve 3 steps in your code.
  1. learn and implement EEPROM emulation techniques and software for STM32 Microcontrollers - Application note
  2. before poweroff store text to eeprom space
  3. after poweron load back in screen or main setup stage
Maybe you dont need emulation , when your MCU have internal EEPROM or you use an external...
