Bug report: TouchGFX Designer 4.18.1 does not regenerate text source files properly if assets\texts\ is changed directly.
Tuoman
Senior II
TouchGFX does not recognize if changes have been made into this file externally.
Reproduce: make changes in assets\texts\texts.xml file -> regenerate with Designer -> texts/src/LanguageXXX.cpp source files are not regenerated properly.
Fix: make changes in Designer -> regenerate -> files are now regenerated properly.
Hopefully will be fixed. We edit assets/texts with scripts, and this workflow is not good.
1 REPLY 1
Alexandre RENOUX
Principal
Hello Tuoman,
I cannot reproduce your issue.
Can you be more precise on how to reproduce the issue (with images to illustrate if possible) ?
The easier it is to understand the problem the faster it can be fixed :)
/Alexandre
